Hello Everyone,
I have an interrogation on 2D view : when i use fonction Align (for 2 lines example), the padlock do not appear.
Is there a selection in the setting for Activity / Disabled the padlock?
Thanks in advance,
Guillaume
Hello Everyone,
Thanks in advance,
Guillaume
Can you post a screen capture of how you are wanting to use the align function? What have you tried thus far?
I just use the align fonction like usually between two lign and when i check to use the padlock, it was not disponible.
Also, concerning the version, we use Revit 2017.2.
Guillaume
It is possible, as shown here for faces.
Revut.DB.References can be extracted from existing elements but some conversion may be required to get a workflow that suits your needs. Can you be more specific on what you are aligning? I recommend having a go and posting back with you efforts if you encounter roadblocks ![]()
Thanks Ewan for your reply.
I didn’t not espect use RevitAPI for this little subject !
If the padlock was mask, the are a command in the first interface to activate/desactivate ?
Guillaume
It looks like a Revit issue, not a Dynamo one. Apparently someone had the same problem solved here:
Thank you @lucamanzoni,
That’s right !
the padlock acts as a separate object hidden in a workset.
