The challenge with those methods is always to find the references, here is an example that uses uidoc pick face to pick them. This is of course a lot more work than just hitting the lock in revit, but I hope this helps to get you (or someone else) started:
clr.AddReference("RevitAPIUI")
from Autodesk.Revit.Creation import ItemFactoryBase
uidoc = DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
view = doc.ActiveView
if IN[0]:
r1 = uidoc.Selection.PickObject(Selection.ObjectType.Face, 'Pick first face for reference');
r2 = uidoc.Selection.PickObject(Selection.ObjectType.Face, 'Pick second face for reference');
#Do some action in a Transaction
lockedAlign = doc.Create.NewAlignment(view, r1, r2)
OUT = view , lockedAlign
