I have a family that I insert and align with a wall.
I want the family remains aligned after I move the wall.
This is possible by setting this lock.
If I have to place a lot of the same type always have to clicking on the lock.
Is it possible to do this afterwards with a Dynamo script?
So if I placed the families and I aligned them use the Dynamo script and turn all the families that are aligned on lock.
The challenge with those methods is always to find the references, here is an example that uses uidoc pick face to pick them. This is of course a lot more work than just hitting the lock in revit, but I hope this helps to get you (or someone else) started:
clr.AddReference('RevitAPI')
from Autodesk.Revit.Creation import ItemFactoryBase
view = doc.ActiveView
if IN[0]:
r1 = uidoc.Selection.PickObject(Selection.ObjectType.Face, 'Pick first face for reference');
r2 = uidoc.Selection.PickObject(Selection.ObjectType.Face, 'Pick second face for reference');
lockedAlign = doc.Create.NewAlignment(view, r1, r2)
OUT = view , lockedAlign
I have the same problem. I have tried the python script and it’s work but I want to modify it, I don’t want select the faces but integrate the face before the node.
I tried this (with IN[1] and IN[2] with the node “select face”)
if IN[0]:
r1 = IN[1];
r2 = IN[2];
