I am trying to tag all rebar in a locked 3D view but am getting an error saying “View does not support annotations” . When I manually tag all within revit, the elements get tagged so I know that the elements can be tagged. Whilst I know I can use the tag all elements feature within Revit to tag everything I want to be able to filter out elements using dynamo and only tag a selection of elements.
Any idea why this may not be working properly?
Are you definitely in a 3D view and not a perspective?
Hi Brett,
I have the exact same issue, and I was wondering if you had been able to solve your problem?
Cheers
Well it looks like I also got here, can i hope in any update about this tread?
Can you post what you’re stuck on?
I have the same problem, does the 3d view not support tag using dynamo?
Any solution for this? Anyone?
This thread is over 2 years old at this point and doesn’t have much data in terms of what people were trying to do. Start a new topic and post the RVT and DYN showing where you are stuck.
I found a solution, I will post it here.
Apparently the API method changed in 2016.
I had no luck with OOB nodes.
A python script solved it.
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
from Autodesk.Revit.Creation import Document
view = IN[0][0]
elem = IN[1]
pts = IN[2]
dataEnteringNode = IN
r = []
for e, p in zip(elem, pts):
d = UnwrapElement(e)
v = UnwrapElement(view)
t = IndependentTag.Create(doc, v.Id, Reference(d), False, TagMode.TM_ADDBY_CATEGORY, TagOrientation.Horizontal, p.ToXyz())
r.append(t)
# Place your code below this line
OUT = r, v
Can you please post a screenshot of your Dynamo nodes? I tried it but the python script gave me an error saying axonometric views is unscriptable. I am using a locked 3D view.
