Hi everyone, I tried the packet, Wall Finishes by Rooms. Unfortunately it does not work. Also the original file from the script. Can it be related to the German version of Revit?
my projekt looks like this, there are listet the rooms, but there are no wall in the modells
Scripts can be used in any language really, the bits that will differ is project specific. For example, if you are changing the height of an object, in the English version of the script it will be looking for parameter “Height” but in German it would be “Höhe” ( Translated from google ) but apart from that; it should all work fine.
It’s not related to language settings of Revit. You’re doing something wrong or using old nodes with new API.
Your definition probably throws out errors - a screenshot would be useful.
having the Problem myself and cant figure out what you changed. could you maybe publish your changed Dynamo file here? would be greatly appreciated. cheers. mo
