WallFinishing.dyn (52.0 KB)
Hi guys,
I would like to use this script to create wall finishes. When I have a level with multiple rooms then everything works. Unfortunately, it doesn’t work if I have multiple rooms on multiple levels.
After I run the script, the wall finishing of Room 2 is not on the ground floor, but on the first floor (one floor above in room 4). On the second floor is also the wall finishing of room 4. So there are two wall finishes in Room 4. Once from Room 2 and once from Room 4.
Everything is correct in rooms 1 and 3. There is no displacement of the wall finishing.
I am not allowed to use a python script for this task.
Can someone help me or upgrade my dynamo script? Thanks in advance
