I have a Python script that generates a curtain wall as an output - however, the Mullion.ByElement node fails to get the mullions from this wall. I can get it to work if I do the following:
- Disconnect the Python script from the Mullion.ByElement node
- Run the script
- Reconnect the Python script
- Run the script again
It seems pretty dumb having to do that every time I want to use the script. Does anyone know how I can fix this issue?
For reference, I connected another Mullion.ByElement node to a Select Model Element node with a curtain wall selected, and it works fine.
The Python script is below:
import sys
# Import DocumentManager
# Import RevitAPI
clr.AddReference("RevitAPI")
#Add list object
profileCurves = IN[0]
filledRegionCurves = IN[1]
newWallType = UnwrapElement(IN[2])
inputWall = UnwrapElement(IN[3])
view = UnwrapElement(IN[4])
filledRegionType = UnwrapElement(IN[5])
output = []
#Functions
def createCurveLoops(curveGroups):
curveLoops = List[CurveLoop]()
for group in curveGroups:
revitCurves = [c.ToRevitType() for c in group]
curveLoop = CurveLoop()
for curve in revitCurves:
curveLoop.Append(curve)
curveLoops.Add(curveLoop)
return curveLoops
#Get parameters from input wall
inputTopConstraintId = inputWall.get_Parameter(BuiltInParameter.WALL_HEIGHT_TYPE).AsElementId()
inputUnconnectedHeightId = inputWall.get_Parameter(BuiltInParameter.WALL_USER_HEIGHT_PARAM).AsDouble()
#Get curves from input detail component
curves = List[Curve]()
for profileCurve in profileCurves:
curves.Add(profileCurve.ToRevitType())
#Create curveloops with filled region curves
curveLoops = createCurveLoops(filledRegionCurves)
#Start transaction
#Created non-intersecting filled region
newRegion = None;
try:
newRegion = FilledRegion.Create(doc, filledRegionType.Id, view.Id, curveLoops)
except:
newRegion = "nahhh bro";
#Create new wall from input curves
newWall = None;
try:
newWall = Wall.Create(doc, curves, False)
newWall.WallType = newWallType
#Set new wall parameters
newWall.get_Parameter(BuiltInParameter.WALL_HEIGHT_TYPE).Set(inputTopConstraintId)
newWall.get_Parameter(BuiltInParameter.WALL_USER_HEIGHT_PARAM).Set(inputUnconnectedHeightId)
#Disallow wall joins
WallUtils.DisallowWallJoinAtEnd(newWall, 0)
WallUtils.DisallowWallJoinAtEnd(newWall, 1)
except:
newWall = "Dis aint be workin"
OUT = newWall
Dynamo wonât reach-execute nodes unless their input had changed. If you provide an extra input into the Python node you can just toggle a switch boolean node) or adjust a slider and the node will reexecute.
Alternatively you can leverage Dynamomplayer instead of Dynamo.
Hi Jacob, I donât understand what you mean by âreach-executeâ. Could you expand on that? Wouldnât the Python script execute and return the wall output before the Mullion.ByElement node attempts to execute?
Sorry that was an autocorrect issue. Re-execute. Dynamo wonât re-execute a node unless an input changes.
Therefore the Python runs once, and wonât run again unless something new is provided into it. A boolean node which you toggle before hitting run will do just that.
Thanks for the advice, but connecting and toggling a bool does not change the result. Using Dynamo Player doesnât solve the issue either. Any other ideas?
I also donât understand why the node needs to re-execute at all. The Python script outputs a wall element, and the Select Model Element node also outputs a wall element. The Mullion.ByElement node connected to the Python script doesnât work, but the Mullion.ByElement node connected to Select Model Element does work. Why is that?
Need a project and the .dyn to test with.
No problem, hereâs a download link with the test model, test link and .dyn: WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
After running the script, I select the link then select all the windows from the 3D - Windows view.
Please note, the issue I described in this topic (Dynamo symbolic line geometry generating in wrong location) also applies to this script. I would be very happy if you have a solution to this problem, but it not, you will need to run the script, wire the FamilyInstance.ByPointInView node to the Python script and then re-run it to get the script to execute to the point we have been discussing.
Thanks for your time!
Just giving a boost to see if anyone has other ideas about how to resolve this. Still searching for a solution.
Tried wrapping my head around what youâre after twice now, and canât figure it out. Mostly this is due to the initial state of the garph having some rather particular aspects around the selection effort. What type of objects I am supposed to select in the link isnât clear, nor is the relationship to the live element which is in the âselect model elementâ node.
The intent of the graph isnât really clear either. The name âWindow Openings and Mullionsâ is a bit ambiguous as far as names go. My best guess is that youâre trying to:
- Generate a curtain wall from the profile of another wall
- Find the windows in the curtain wall and add some mullions at these locations in the new curtain wall
- Set the mullion type based on some property of the resulting mullions
However none of that really makes sense as youâve already got a curtain wall selected⌠Likely there is a better way to go about what youâre after if this is the case, but Iâd need to know more of the goal and initial state.
All of that said I think I can identify the route cause by digging into the logic flows which I can identify.
Youâre generating a wall with your Python script, and then asking it for itâs mullions. As mullions are second level content they donât exist until the transaction is complete; So we can try wiring the result of the Python node into a Transaction.End node, and that into a Transaction.Start node. This will âwrap upâ generating the curtain wall, then start a transaction so we can commit any changes to the new curtain wall.
Give that a try and see what you get.
The Tranastion.Start and .End nodes solve the problem! Thank you so much, Iâve been wracking my brain over that one for a while.
My apologies, I could have been more clear on the intent of the graph and understand why itâs confusing. The intent is to modify the profile of the selected curtain wall around the windows in a linked model, using the lines of a detail component that is placed at each window location. After the wall has been modified, I am changing the automatically generated mullions to the correct mullion types, representing head, sill and track studs.
Itâs extra confusing because I was having trouble figuring out how to modify a wall profile using Revit API, so instead I am generating a new wall from a curve list with the modified profile, then deleting the original wall.
Before:
After:
Gotcha on the intent. It might be better to generate the wall from the face of the existing wall. This will simplify the isolation of the windows and such - theyâd already be a part of the wall. For modifying existing wall sketches this may help though: Sketch Lines - Edit, Copy, Paste - #20 by jacob.small
I am curious as to why youâre putting curtain walls in place over solid walls, but perhaps thatâs a question for another day.
Thanks Jacob, Iâll check out that topic.
We use curtain walls to generate stud schedules from curtain wall mullions for fabrication purposes.
Ah. I am not really a fan of that method, but what you are after with the graph makes sense now.
Interesting, what alternate approach do you prefer and why? I would be interested in your recommendations.
In general itâs overmodeling. But I get that there is a need for it in some cases.
In such cases adaptive components can make sort work of it. Repeaters make the process easy to scale. The corner conditions and framing can readily be incorporated into the process. And it works for ceilings too.
Right on - I need to get more experience with adaptive components. Thanks for the tip.
