Wall by python script
hi everyone, I’m trying to create a wall by python script but it shows some error please guide me.
clr.AddReference("RevitAPI")
#clr.AddReference(‘ProtoGeometry’)
#from Autodesk.DesignScript.Geometry import *
if isinstance(IN[0], list):
lines = IN[0]
lines = [IN[0]]
level = UnwrapElement(IN[1])
type = UnwrapElement(IN[2])
Struc = IN[3]
ele =
for i in lines:
wall = Wall.Create(doc,lines,type.Id,level.Id,Struc)
ele.append(wall)
OUT = wall
Hey,
If you wouldn’t mind hitting image when you paste code it will keep the formatting.
If you’re pasting code with inputs, then we’ll want to see the dynamo graph to check that your inputs are what they should be. Right now you have Struct coming IN[3] that should be a boolean, but perhaps you are feeding something else?
Here’s a bit of working code for you to look at…
Hope that helps,
Mark
thanks, @Mark.Ackerley
this is my graph
No worries, thanks.
If you could edit your code to add formatting it will help…
Right now you’re feeding a 5mm long line to create a 300mm wide wall?
Maybe that’s the problem?
i did 5000mm but it shows same error, how to add formatting??
Edit and click image
You need to convert your dynamo curve in Revit curve (ToRevitType()) and the method you use is for walls per profile:
clr.AddReference('RevitAPI')
	lines = IN[0]
	lines = [IN[0]]
Struc = IN[3]
ele= []
for i in lines:
	wall = Wall.Create(doc,i.ToRevitType(),level.Id,Struc)
	wall.ChangeTypeId(type.Id)
	ele.append(wall)
OUT = wall
wow its working thanks :grinning: @Alban
