Hi Guys,
I’m new here and i have a question about python in Revit. I’m trying to make a Wall by profile using Python. This is the code i’m using:
from System.Collections.Generic import List as Lst
clr.AddReference(‘RevitApi’)
from Autodesk.Revit.DB import Wall, Curve
curves = IN[0]
levels = IN[1]
types = IN[2]
walls = []
index = 0
# Validatie
# if (validatie not ok)
# show error
# else
for curve in curves:
** for loop in curve:**
** profile = LstCurve**
** for i in loop:**
** profile.Add(i.ToRevitType())**
** wall = Wall.Create(doc, profile, UnwrapElement(types[index]).Id, UnwrapElement(levels[index]).Id, False)**
** walls.append(wall)**
** index = index + 1**
OUT = walls
I didn’t write it myself: a collegue found it somewere online. In Revit 2018/Dynamo 1.3.3 the code worked fine, but using Revit 2019/Dynamo 2.0.3 i can’t get it to work.
Ik keep getting this error:
Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed. **
** File “”, line 38, in
TypeError: iteration over non-sequence of type Curve
Can someone please help me? I’m a little bit lost here!
I apologize for my Eglish, it’s not my native language… sorry!
Thank you in advance!
