I’m trying to create a wall using Pythonscript and revit api, but I don’t know how. Please help me.
You have an error in the level input line
It should be
level = UnwrapElement(IN[0])
0 not 1 judging from your node setup
actually your node inputs don’t match ones in code - you should start with fixing that…
You can try a script like this:
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import Wall
lines = UnwrapElement(IN[1])
walls = []
for l in lines:
w = Wall.Create(doc, l.ToRevitType(), level.Id, False)
walls.append(w)
OUT = walls
Sorry, I uploaded the wrong image. Image modified.
One more time please.
python function len(something) gives you an integer length of ‘something’. You cannot iterate over integer - that is your error in yellow. To do an indexed iteration like so check the ‘range’ function in python…However there is no need to use indices - check my answer above (the one with code).
Thank you, it was very helpful :>
I believe there is no function in RevitAPI that creates wall without specifying a location curve.
As for the type - it is not a wall type. This conversion is necessary because Dynamo objects are not Revit objects. So in order to pass a curve as a parameter to Revit API function it has to be converted from Dynamo-kind curve into Revit-kind curve.
In your Script there is a conflict ‘Wall’s Class’ between 2 Namespaces
Revit.Elements and Autodesk.Revit.DB
from Revit.Elements import *
one solution is to assign the Revit class Wall to an alias (example RvtWall)
#import Revit API
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import Wall as RvtWall
walls = []
for l in lines:
w = RvtWall.Create(doc, l.ToRevitType(), level.Id, False)
walls.append(w)
OUT = walls
It is way easier just to remove the line that brings confusion and is unneccessary
In general it is best practice not to use ‘*’ on imports and import only stuff you need.
@antoniocanerosan
you can use this method instead
Thanks @c.poupin
I have issues getting the wallType.Id, could you please assist?
Note: lines list IN[0] are a list of polygons
output = []
lines = IN[0].ToRevitType()
#Create Curve Array
carray = CurveArray()
#Loop through lines
for line in lines:
carray.Append(line)
#Start Transaction
#Create Floor
floor = doc.Create.NewFloor(carray, False)
output.append(floor.ToDSType(False))
#Get Floor Parameters
level = floor.LookupParameter("Level").AsElementId()
height = 1000
offset = 5
#wallType = 2763524
#Create Walls
for line in lines:
wall = Wall.Create(doc, line, wallType.Id, level,height,offset,False, False)
output.append(wall.ToDSType(False))
#End Transaction
OUT = output, level
Thanks in advance
@antoniocanerosan
you can use the OOTB node “Wall Types”
Merci beaucoup @c.poupin !
Appreciate your answer always!
