I am struggling with trying to create mullions on a curtain wall, using a spreadsheet as data. Am using a Python script to create the mullions and Dynamo nodes for the rest.
The issue is when I try to connect the output of a dictionary to the Python script, it will give me an error:
But, if I just plug in the name to the FamilyType.ByName node, it will work fine:
Python script (found on this forum):
import sys
# Import RevitAPI
clr.AddReference("RevitAPI")
#Variables
grids = UnwrapElement(IN[0])
mullType = UnwrapElement(IN[1])
mullions = []
#Start Transaction
#Add Mullion to Grid Line
for g in grids:
mullions.append(g.AddMullions(g.FullCurve,doc.GetElement(mullType.Id),False))
#Stop Transaction
OUT = mullions
My hunch is that there is something in the dictionary output that makes it error, but it looks totally fine. I tried a Flatten after the dictionary, but same error. Have also played around with Lacing, but same issue.
Any insight is appreciated.
Thanks,
@lorhal
