Move View to another Sheet
Hello all,
I have been looking but I cannot seem to find a way to move a view from one sheet to another.
I am trying to match a source file for view placement. I have matched the views and sheets but I cannot find a way to move the view to its proper sheet.
Is there a node or a package that I am glancing over?
Thanks,
Did you find this topic?
Hey Ewan,
Thanks for the Reply. I had not seen your post on that thread.
I pulled out the python code and it seems to be working. Do you know what package the code came from? I know Rhythm has one but it was not working for me (I think I had a view that was placed in my list going to check on that now).
To place a View onto another sheet one must first delete the viewport (not the view). See image below.
Here is the python code from Ewan script (provided in the link above). Looks like it was originally written by @Julien_Benoit1
#python nodes in dynamo 1.2
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
sheets = []
for i in IN[0]:
sheets.append(UnwrapElement(i))
views=[]
for i in IN[1]:
views.append(UnwrapElement(i))
points=[]
for i in IN[2]:
points.append(UnwrapElement(i).ToXyz())
# Start Transaction
viewp=[]
for s,v,p in zip(sheets,views,points):
a=Viewport.Create(doc, s.Id,v.Id, p)
viewp.append(a)
# End Transaction
OUT=viewp
Thanks, Ewan for the lead,
Hi Steven,
Yes, this python was from the #steamnodes package and was within the node Tool.PlaceViewsOnSheets.
(Steamnodes is a cool package to keep handy :grinning: @Julien_Benoit1 :+1: )
The only reason I took this out into python for the graph was to reduce the dependencies, as I hadn’t gotten Dynamo player set up to work with network packages for our team at the time.
Glad you got it sorted.
Thank you very much. It works.
