Place existing view on existing sheet issue [null]
I read several threads about problem of placing views on sheets but none seems to help me. I wanted to do simple thing for start - get a specific sheet and place a specific view on it. No luck… :frowning: I get null output - anyone knows what’s going on here?
Quick questions :
  • Are you in Manual mode ? If so, have you hit Run ?
  • What version of Dynamo are you using and which version of Dynamo is supported by this package ?
  • Could you try to copy and paste the content of the custom node in your graph and running it ? It may help to see where the problem is encountered.
Yes, I did run it. 1.3.2
#python nodes in dynamo 1.2
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
sheets = []
for i in IN[0]:
sheets.append(UnwrapElement(i))
views=[]
for i in IN[1]:
views.append(UnwrapElement(i))
points=[]
for i in IN[2]:
points.append(UnwrapElement(i).ToXyz())
# Start Transaction
viewport=[]
for s,v,p in zip(sheets,views,points):
try:
a=Viewport.Create(doc, s.Id,v.Id, p)
except:
a="View is already placed"
viewport.append(a)
# End Transaction
OUT=viewport
sheetplace.dyn (11.0 KB)
Sorry, maybe I was unclear. Can you paste this Python script on your .dyn and directly connecting the inputs to it ? The Python node will certainely output an error and we will see where it is bugging :slight_smile:
Ok, to be sure - I placed Python node, pasted the code there and added two more inputs.
The error I get is:
File “”, line 30, in
TypeError: iteration over non-sequence of type Sheet
p.s.
Does it mean it expect lists?
p.p.s.
Ok, so I created lists for input but now I get no error and no effect :smiley:
That would also be my guess :slight_smile:
Is the Python node still returning null ? Or returning an empty list or something ?
My fault - I tried to place view already placed on sheet! BUT I then decided to place a schedule which can be placed on multiple sheets and still get the same message. Will try to create a specific new view to test it.
p.s.
It went fine with newly created view but I wonder why Schedule didn’t work.
Hi everyone, I try to do the same one to place an active view on current sheet! It used to work before but suddenly come null, anyone has a hint please.
Place current view on sheet.dyn (20.3 KB)
