The object in the following video was imported via IFC into Revit.
As you’ll see there, if you select it the 1st time, no ‘shape handles’ are made available.
If, however, you enter the ‘edit in place’ mode and then exit that mode, you can see the shape handles are now made available.
Is there a way, to have these ‘shape handles’ immediately available after import without having to enter into ‘edit in place’ mode?
Or is there an existing script out there, that could run through all the MIP families at one time, and make these ‘shape handles’ available?
