List total values from Schedules in Revit
Hi everyone,
I’m a freshman in Dynamo. I need your help to reduce my freshness :).
I’m in trouble with Schedule in Revit. I have a lot of schedules to calculate the value of: Site Coverage, Garden Area, Site Permeability with both in Area and Percentage.
Now I want to create a list of that total calculate Parameters, somethings like below:
SITE AREA_____________: X m2 (Get from Project Parameter on Area + Project Information)
SITE COVERAGE_______: X1 m2_________Y1% (Total value from Site coverage Schedule)
SITE PERMEABILITY____: X2 m2_________Y2% (Total value from Site Permeability Schedule)
GARDEN AREA________: X3 m2_________Y3% (Total value from Garden Area Schedule)
Could you please show me the right way to do?
Many thanks,
Hi @daotangluc ,
Welcome to the forum :grinning:
Thanks for your guidelines. I’m working on that. Still struggle but have some small steps.
I started to create on Dynamo like the image.
I can export the value from Site Area (Project Parameter) to Excel file
but how could I get the total value of other Calculate Parameter (Site Coverage, Site Permeability, Garden Area)
Thanks in advance,
@daotangluc You can create a list of all parameters like this:
Set lacing to longest
Thank you so much,
I discover another issue, SITE AREA is Project Information, but the others are Areas
So I change the codes, but the new issue is how could I get the total value of one Calculate Parameter?
@daotangluc
This could help ?
@salvatoredragotta
Thank you so much.
Now, I can get the value from schedule, but I can’t summarize the value with SUM
Which is my mistake?
@daotangluc
Use a Object.Type node and check your data. Math.Sum can just add integers/doubles
I check, but the object type is null.
What happened with the values?
Thanks,
@daotangluc
@salvatoredragotta: thanks for your help,
So I succeeded to export to excel as image.
But now, how could I import that excel to drafting view/Legend?
Or could I put the values to Text parameter and show in another schedule?
@daotangluc Glad you to hear!. Please mark this topic as solved and start a new topic for your new issue.
