Linked File Unable to Geometry intersection
I have an architectural file linked with an MEP file, using Project Base Point to Project Base Point.
However, when I run geometry clash detection, there is no response.
Could you please advise what adjustments may be needed?
model files and dynamo dyn
https://drive.google.com/drive/folders/1gzTABjTwkxIHotAPsCaCf4ihiK-j-i2v?usp=sharing
Look into package bimorphNodes. Works with links and it‘s crazy fast.
hi andreas
thanks your suggest
It seems that the linked file’s base needs to be transformed in order to generate geometry clashes. Otherwise, although the walls and pipes appear to be aligned in the view, the program reads the geometry coordinates as being very far apart.
