I have a working script that does the following:
- Reads an excel file, creates views based on the levels in the model
- Creates views based on the levels in the model, renames the views based on the excel file
- Assigns view templates to views created.
- When it gets to the sheet creation portion, I’m using the node Sheet.ByNameNumberTitleBlockAndViews, but it is not placing the views created on sheets. It creates the sheets, even though it requires views to be fed into the node, but it’s not finishing the process even though i don’t get any errors. I’ve provided the script, the excel file index, and a sample Revit border to load in where they’re needed. Any advice helps!
Sheet & View Setup - Excel Index.dyn (129.6 KB) D 22 x 34 Horizontal.rfa (356 KB) Master Sheet Index.xlsx (26.2 KB)
