Issue with replacing floor-based families with face-based families
Hello all,
I am posting here because I need some help.
The firm I work at, we create a lot of as-built drawings/models. and we have decided to go from wall/ceiling/floor/etc. hosted families to face-based. We are now faced with the task of updating our models.
I thought I could use dynamo to quickly replace all of the floor-hosted families with the face-based ones, but it is proving difficult. I am able to pull all of the existing elements (floor-based) by their points (X,Y,Z) but when I go to place the new (face-based) families by points, it places them correctly by their X,Y but their Z axis always comes in at 0.
I have tried FamilyInstance.ByPoint and FamiliyInstance.ByCoordinates to no avail, and also Springs.HostedInstance.ByPoints. I’m guessing it is something to do with the family wanting to inserted at a vertical face, and when the floor isn’t vertical, it just disregards the Z-value and it comes in at (X,Y,0).
Has anyone had any issues with this or any solutions?
Thank you for reading this. Any help / ideas would be appreciated.
Thank you!
Can you manually place the family horizontally? If so check out the springs.hostedinstancebypoints node in the springs package.
Thanks for the suggestion JacobSmall.
I will try placing it horizontally; I think it defaults to be placed on a vertical face.
I tried the springs.hostedinstancebypoints node but it didn’t work. I am thinking maybe I have to go host by host or level by level.
Host by face - harder to get a face than an element in the api.
I figured it out; will post workflow soon. OOTB Dynamo Nodes.
By filtering the old family’s host, I was able to go host by host and replace them by using FamilyInstance.ByFace using a location and a reference direction perpendicular to the face.
Because it defaults to being placed on a vertical face, make sure the reference direction is parallel to the face you would like to place. It is essentially placing it parallel (the families vertical) to the floor.
Workspace:
I think this graph will also solve your issue. Composed in 1.34
1.34_Replace Floor Based Families with Face-Based Families.dyn (19.6 KB)
