Issue placing views on sheets
Dynamo is giving me a issue when I try to place a cropped view (trough scope box) into a sheet.
It’s say that the views is too big to be placed inside the sheet.
I think that dynamo is computing the whole floor view, not the cropped one.
Any suggestions?
Thanks!
This node get some error, you can try python script to place view on sheets.
Thanks !
I think you might need to change the scale of the view so that the view fits on your drawing sheet?
Did you try any of the lacing options? Also, sheet name and number should be listed before with views so that the lacing will work.
…and double check that none of the views aren’t already placed. You’re going to need to proverbially start from scratch each-time to test it.
Try this from “MyVit” package . :grin:
