Hi All. How does one get the door hand instance in dynamo? In the below I want to determine if its right facing vs left facing etc. But that you need the door handle instance properties.
It’s a topic which has come up a lot if you search the forum, there are nodes in Archi-Lab and clockwork, here’s an example graph… As noted you need to ensure there are rooms present…
Hope that helps,
Mark
