How can I import an entire row/column from Excel to Dynamo and continue with the numbers that are my element IDs, I am going to continue with?
This can get you started: Dynamo Dictionary
Thank you, but where can I find Excel.ReadFromFile?
Sorry - looks like I sent the link to the 1.x node instead of the 2.x.
https://dictionary.dynamobim.com/2/#/ImportExport/Data/Action/ImportExcel
Hey again, I find the problem.
It was the Code block node who was the problem.
Glad it worked out. Can you mark a solution or post one and mark that if there isn’t a clear one yet?
But can you help me now with the values (element IDs)
The element IDs are Warnings, which I want to correct, however I only want to see the Element IDs that are on the work plan I am currently working on.
Thank you!
Best to start a new topic. Be sure to give more info than you have included here as there isn’t’ a way for anyone to know what you’re after or deciphering which warnings are in which model. This Archi-Lab post might be a better workflow overall: https://archi-lab.net/digging-through-revit-warnings-to-find-meaning/.
Okay, thank you!
