Hi, all!
Experienced Rhino/GH user moving to Dynamo.
I got level contour polylines, all closed and planar, and I want to “merge” the pair of courves on each level to get a final “common” contour for the floor slabs.
In Rhino it would be fairly easy with “booleancurves” and “join regions” in GH.
Little help on how to achieve this, please?
Welcome to Dynamo Forum!
There is a custom node from archi-lab package that will merge the pair of curves.
Thx! Will try it right now!!
Seems to mix things weirdly. All polylines are paired on levels and construction is clear, but apparently the ouput of the component is not straight…
Can you show us screenshot of the graph with error expanded.
Using a more up to date version of Dynamo, You may try adjusting the Group Curves node input to list @ level 02…
