Hi guys,
rather simple yet annoying thing, is it not possible to join Lines and Curves ?
The closest thing I found on a post was a Curve.FromLine Node of Rythm, which is not working on my dynamo due to Dynamo version.
Any other solutions ?
A line is a curve type, just with another name since it is completely straight. What does the error say in the Curve.Join node and how do your curve look before joining?
i like to work with firstItem and restItem and than i join the curve @hassan.orion
Keep in mind that node is for joining a single curve to a group of curves by forming a polycurve. Each one of those curves would have to be individually able to attach to those two lines.
Does that mean I have to make a python loop to join them ?
the curves/lines are not in order, would take long to extract and gather their respective indices.
It mostly means you have the wrong node if that’s what you’re after. There’s a PolyCurve.ByJoinedCurves that takes a list of curves and creates a single polycurve. That sounds more like what you’re after. You just need to combine all your curves into a single list first.
