I using Dynamo to change Filter of multi view template but Dynamo Node Can’t choose [No Override]
‘No override’ isn’t a fill pattern element, it’s a lack of fill pattern element. i.e. null.
Feed a null object into your foreground pattern input when creating the override (or no input, depends how you’re doing it and what nodes you’re using).
Is there a problem with your other inputs? If I null out the input (or leave them blank) then I get ‘No override’ in Revit.
In your python you’re using an empty string (“”), which is different from a null object.
