Seem like Dynamo can’t add Filter Override for 3D view. I dit setting but not return result
Thank you!! but “Node” View.SetFilterOverrides Not have “isEnabled”.
I tried using node of Archilab package.
Script is working but not copy to Filter of View template instead copy to View GraphicOverrides
(Script of you the same)
Unfortunately, you will not be able to obtain the 3D view template to apply the filters to. This is a limitation of Dynamo. If you search the forum, you should find the topic of collecting 3D view templates discussed before.
Thank you so much!
