i am new to making dynamo graphs to do revit tasks.
i used the attached dynamo graph to extract dimension values of revit dimension and tried to export the values along with dimension suffix text into excel. but failed
please see below image of dimenions in revit i want to extract dimension values from and export them to revit.
thanks for your help. after change, see an excel sheet showing many rows with the cells having the words “dimension” but see no numbers. after second run, no more excel values show.
“There are nodes to get the value/suffix/etc from these dimension elements.”
but my orignal idea is to extract the numbers with a specific dimension suffixes and export the numbers along with the suffxies to excel.
Once you have those suffixes you could check if that suffix equals/contains/startswith a piece of text in a string, then use FilterByBoolMask to get the dims that match that check, you can then get the value of those dimensions and suffixes to export.
i think there is a node named dimension.style out there, i am using dynamo 1.8, i couldn’t find dimension.style node in it even after i installed archi-lab package for 2024.217.
Can’t see anything in that image as it’s so tiny and the labels are hidden. But based on the error, you’re not feeding the dimension into the suffix node, but instead a piece of text. You need to use the dimension element(s) as an input.
As before, can’t see your image so straight guessing here, but I think you need to do something like this:
(noting that this skips a few nodes so you’ll need to rework how those are integrated into the graph.)
I’m assuming the first 2 nodes are Category and All Elements of Category and the orange node is the Dimension.Suffix.
The ‘All Elements of Category’ is getting the dimension elements. The nodes you’re using after that are getting info from these elements such as the suffix, value, view, type, etc, which are now no longer dimension elements so the suffix node can’t retrieve a value.
i am trying to test from above but i am trying to get the number of the dimension from revit file and export to excel. what should i do? now even i do not do any filtering , the export of all elements of dimesion only give me the word “dimension” in excel. but i actually want the value of dimesions in excel.
‘All Elements of Category’ is collecting the dimensions elements that are simply reporting as “Dimension” in your export. If you use the dimension value/suffix/prefix/etc nodes after ‘All Elements of Category’ you’ll get that data. You could collect all of these and then use ‘List Create’ then feed the resulting list of lists into the Excel input if you want more than one parameter.
