Hello Guys
I’m exporting Sheets from Revit to Excel.
But, I have problems in scale Column.
- The scale numbers from Dynamo Change into decimal numbers when I put them into Excel.
But it understand As indicated?
![image](https://us1.discourse-cdn.com/flex022/uploads/dynamobim/original/3X/2/e/2e7ef3e68996293225014fc61f81d658295fb4cf.png)
Hello Guys
I cant fully see your script so i am not sure, but maybe you could add a object.tostring node.
If this doesnt work for you, please upload your Dynamo/ Revit files so we could also take a look for you
Prøve_T3AE_Export_sheet_from_Revit_to_Excel.dyn (90.9 KB)
That’s my Dynamo script.
the problem is, I have to columns with scale.
Look into the excel formatting of your excel file… excel is automatically transforming the 1:500 (or whatever) scales into values. I can’t explain why the values are getting translated the way that they are (1:100 should be translated as ‘0.01’, for example), but the problem will be related to that I think.
I have look in Excel formatting, but I couldn’t come to the result.
But can you help me with As indicated?
