Exporting Type Parameters and values to EXCEL
Hi GUYS,
I have been trying to create a graph that exporting the Type parameters into Excel so far i haven’t been able to successful.
i want to be able to export the
ADBGROUP : 3
ADBDescription: Computer Monitor etc
ADBCode: COM049
hi there could you upload a picture of wat you have at the moment
This is what i have at the moment and i dont believe its picking up anything
I am trying to achieve this in exel so when the excel spreadsheet is updated i can run a script that would update the information in revit
put Element.ElementType node after all elements of categories that will doe the trick
excellent that’s worked thanks again one more question how can i now separate the parameter and the value in to separate columns ?
you could just do as you where in the first graph u sended
DYNAMOBIM%205
Thanks David,
can i also specify in a list the only 3 parameters i need rather than everything within the whole project
DYNAMOBIM%206
I only need the parameters from List 0 which node would i need to only show this please thanks for the help so far ?
Just make the same graph you had and put element.elementtype node between all elements of categories and the element.getparametervalue node that will work
It doesn’t matter if item 0 is a list or something else (single value)
Are you able to show me an example please.
For S.Rooble.dyn (13.4 KB)
Check this out and let me know if it works
This is perfect thank you David, this has succesfully exported out the values, anyways i could get the headers to appear to to show it coorisponds with the revit headings such as ADBCode, ADBGuide, ADBDescription
Now you can export it to excel and rename it :muscle:
Thank for that I have bee trying to do the reverse and fill in the excel with new data and run it through dynamo with a different script and update the revit values but seems to be an error in the last node any ideas. ???
0%20Dynamo%20Graph
Maybe your putting to much data in the setparameterbyname node try to make more of those nodes
Hey my scripts seem to be working most of the times however i have a small issue my node is still coming up with an error how can i make it so its grey i am only using it for 1 excel column to be updated within the Revit parameters. 4
