Hi everyone, I was looking for this solution, but I’ve not found anything.
I am wondering if it is possible to use the value of some property set data to modify appearance of cross section elements (such as for instance depth or width of some elements) without using Dynamo in Civil3d.
Is this possible? Does it exist a way for doing this?
Regards
Without using Dynamo?
Yes i would like to know if it is possible to do that without using dynamo, by passing the values to some parametrrs.
I think it is not possible, but i would like to hear from expert users
GS
I think a different forum might be a better place for that question if you specifically don’t want to use Dynamo, since this forum is dedicated to Dynamo. Perhaps the Civil 3D forum?
Thank you and sorry for the issue.
By the way i asked here because generally dynamo users reach higher levels of customization and I thought they can be still helpful.
However i will write in the forum you have suggested.
Thanks again
