Hello Currently I have this Dynamo Script where I can extract The assembly of the Corridor Parameters to excel . Is there Any way I can Extract it the other way , by that I mean From Excel to civil 3d where once I have Changed the parameters in excel I can run it in civil 3d and the parameters are changed ?
Assembly Parameters.dyn (36.7 KB)
DWG.dwg (941.3 KB)
2.dwg (930.2 KB)
22.xlsx (9.1 KB)
Assembly Parameters.dyn (39.1 KB)
جزاك الله خير اخوي كتير بقدر مساعدتك
First you helped me to export these parameters to excel . Now I want to change these parameters in excel and they can change the Corridor/assembly parameters . Is there anyway to do this ?
انا عاوز اغير الارقام الموجودة بالاكسل ، و بس اغيرن يتغير الارقام الموجودة بالسيفل ٣د
Once I have changed the numbers from excel the numbers will automatically change in the assembly parameter
جزاك الله كل خير يا حبيب القلب
It was made using subassembly composer 2021 maybe thats why
I would appreciate , a script that can have this Idea , I can send you the assembly by email . I cannot send it here I don’t know why
المهم بس اقدر اعدل عل Assembly
من ال Excel
ممكن هيك شي استاذ حسني . جزاك الله خيرا عكل شي حبيب قلبي . المشكلة مطر عليها كرمال هيك
Upload it to the download site
Put the link better
This is the subassembly . Please if it didn’t work try opening it in your version of subassembly composer and save it on your PC ( do a save as on your PC from your subassembly Composer )
معلش استاذ حسني انكليزيتي ما زيادة ، اذا ما مشيت افتحا با subassembly composer
الموجود علي لابتوبك و علا سايف save as
بيمشي الحال
شكرا كتير اللك
اعمل هايك ابعته
هون
2021 (1).txt (13.1 KB)
I have changed it to txt , maybe you need to change it to pkt when you get it . Again thank you soo much for your help
استاذ حسني ربنا يجزيك كل خير و يرزقك من حيث لا تحتسب . مش عارف كيف بدي انشكرك يا حبيب قلبي يسلموا كتير
واياكم
الحمد لله
