Changing multiple parameters using "AppliedSubassembly.SetParameterByName"
Hi everyone, I am new to Dynamo for Civil 3D, and trying to connect this powerful tool with excel. Specifically, I want to read multiple corridor subassembly parameters from excel, and updating these parameters (and subsequently corridors) at one time.
(1) Do we have a functionality dedicated to this? It seems that we have the functionality to update “only one” parameter of a subassembly (AppliedSubassembly.SetParameterByName), but we do not have the one to update “multiple” parameters at one time.
(2) I have made a custom node which extends “AppliedSubassembly.SetParameterByName” and updates multiple subassembly parameters at one time, which is shown below.
import sys
# Add Assemblies for AutoCAD
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
# Add Assemblies for Civil3D
clr.AddReference('AeccDbMgd')
# Add Assemblies for Dynamo (Additional)
clr.AddReference('Civil3DNodes')
# Import references from Dynamo (Additional)
from Autodesk.Civil.DynamoNodes import AppliedSubassembly
def SetParameters(appliedSubassembly, data):
	# Magical spells ...
	editor = adoc.Editor
	with adoc.LockDocument():
		with adoc.Database as db:
				# Update for each subassembly type, section, and parameter
				for i in range(len(appliedSubassembly)):
					for j in range(len(appliedSubassembly[i])):
						for k in range(len(data[i])):
							AppliedSubassembly.SetParameterByName(appliedSubassembly[i][j], data[i][k][0], data[i][k][2], 0)
				# Commit before end transaction
				t.Commit()
				# pass
OUT = SetParameters(IN[0], IN[1])
The .dyn file and .dwg file is attached below.
Subassembly_Params_Import.dyn (40.8 KB)
Subassembly_Params.dwg (1.4 MB)
All I am doing is run “AppliedSubassembly.SetParameterByName” iteratively. But the program gives me an error on reaching to non-editable parameters, so I need to manually get rid of these from excel in advance.
Do you know any workaround on it? (For example, finding out non-editable parameters before running “AppliedSubassembly.SetParameterByName”, or picking up only editable parameters extending “SubassemblyParameter.Name”, etc.)
I would appreciate any kind of replies!
You can use List.Map node for this, if you use AppliedSubassembly.SetParameterByName node as a function.
Best regards
Lukas
