Assembly Parameters to excel
Hello Everyone , I am new to civil3d/Dynamo . Curranty I have an assembly with specific parameters and I want to export the parameters to excel ,Is there any way I can do that using dynamo for example ? The problem is that I have a little knowledge about Dynamo .
Hi @ahmadkhalaf7892.
Look un civil3D dynamo example. There is a example for that.
Regards,
Thanks a Lot for the reply Dear , May I know the name of the dynamo script ?
I am not at PC.
https://help.autodesk.com/view/CIV3D/2020/ENU/?guid=GUID-E2122814-1957-4108-9BBF-0AD6AF1A63CB
Check this link the is intuitive.
Regards
Thank a lots
hi
see this
Hi Many thanks for your reply , I tried the script it didn’t work , I only have these parameters is there any direct way using dynamo I can export them to excel ?
I would appreciate any help a lot
Thanks .
alignmenet.dwg (925.9 KB)
hi
try
Capture
Assembly Parameters 01.dyn (39.2 KB)
Assembly Parameters.xlsx (8.0 KB)
HI Again , I really appreciate the help but the dynamo script isn’t working on this DWG. I am receiving some warnings. to be honest I have too little knowledge regarding dynamo and the company that I started working for needs this script . I am trying to get the assembly Parameters from this DWG . I didn’t know why its not working . I appreciate the help again .
creating Corridor with name Corridor - (1)
Thanks a lot , you just saved my life
Hi what if we have multiple assemblies in corridor how to export all assemblies’ parameter to excel.
Is there any option available @Drbohlav @jacob.small @zachri.jensen
What have you tried so far?
As this topic was solved many moons ago and Dynamo for Civil 3D has evolved a lot since then (seriously any screenshot here should look NOTHING like your screen), it’s likely best to start a new topic showing what you’ve tried so far and provide a dataset for people to frame your question around (otherwise you are asking for a solution to an unclear problem with an unclear dataset and project configuration).
Thank you for your question and for tagging me in the discussion. I take it as an honor. However, I’d be happy to offer my services as a consultant on behalf of a company that is a Platinum Partner of Autodesk, GRAITEC GROUP (www.graitec.com). Otherwise, it’s important to follow the rules of this platform, as users and contributors should not be misused. I wish you great success with Dynamo and look forward to possible future collaboration.
