How to avoid this warning:
This probably doesn’t answer your question, but I believe that in C3D2024’s dynamo, those are not Warnings anymore.
It’s just a warning because your x and y coordinates are too far from the origin (0,0). You can change the scaling, but I do not recommend that.
Ignore it, changing the scaling may result in Dynamo rounding your X,Y,Z values of points, vertices and so on.
Don’t change it
Why not? I’ve always changed mine and it runs smoothly.
It turns the points previously created at 1026281016294.515186 units to points at 1026281016295 units. As a result the solids move by 1/2 of a unit. This doesn’t feel like much, but shifting 1/2 of a unit here or there for a nurbs geometry will lead to your solids no longer closing, and causing other downstream reactions to things.
To fix this you could temporarily transpose the data back to the origin as Dynamo does not like data back too far from origin. Just make sure to transpose again back to real world coordinates before exporting data back to CAD.
