Can someone explain how the CS part works?
Lets say i wanna create a Section in the X direction and a Section in the Y direction.
I also have no idea which CoodinateSystem node to use in this case
Or is this not how a Section is created using Dynamo?
What does the error say? You’re min and max points essentially create a line right now instead of a rectangular boundary. I’m guessing the CS is for the view plane, while it looks like you’re providing an XY plane.
That image was (is) great help for me! Basicly all i needed. Thank you! @MJB-online
@Nick_Boyts
I think my thought process was waaaay to simple.
I thought it was the line along the Section would be created.
I have (had) no idea how the node works. I simply just tried stuff this time, but
couldn’t figure it out. Hence this topic
@MJB-online his reply was all i needed!
@MJB-online
This is how i understand the node works. Correct me if i am wrong.
Plane.XZ defines the direction the Secion Line is created.
minPoint is the startting point of the Section Line.
maxPoint is where the Section Line ends and with it controlling the Length Y Height X
and Far Clip Offset Z.
Creating section views based on coordinate systems can be quite challenging, and sometimes drive you crazy.
Points 2 and 3 are completely correct, you should see the sectionviews as a shoebox/boundingbox, with a minpoint and maxpoint.
It is also important that you create/manipulate a coordinate system of which the Z-axis is the viewing direction. The point of view of the section then lies on (or parallel) to the X-Y plane. But because this X-Y plane is sometimes twisted to get the right viewing direction, the X and Y coordinates sometimes have to be swapped, or given a negative value, to get the right effect. It is very useful to visualize the active coordinate system. We have a custom node to do this, below you can see how this works.
And in the past I’ve also often just used the test and trail method until I got the right section views. Good luck.
I tried to explain a little bit about how sections in Revit work here, and put a good bit of the section tools to work: The Stairry Story - Using Dynamo for stairs in Revit - #42 - Community Conversations - YouTube
It’s a bit challenging as Revit utilizes a non-axis aligned bounding box, which while now doable in Dynamo was previously not possible and so we had to imagine the outcome.
