How do you pass a "null" to API function in Python
Hello Everyone;
I am trying to create a Python Script node in dynamo that would return any Dimension elements used inside of a Filled Region object. I see from the Revit Lookup tool that Snoop Dependent Elements gets to where I want to go. Looking at the API, I see a GetDependentElements method and note that I can get all elements by passing a “null” to the method. So the question is: How do you do that in Python?
region = FilteredElementCollector(doc).OfClass(FilledRegion).WhereElementIsNotElementType().ToElements()
out = []
for r in region:
	z = UnwrapElement(r)
	out.append(z.GetDependentElements())
#	out.append(z.GetSubelements())
Sincerely;
Michelle
PS: The overall goal here is to examine all filled regions and masking regions for embedded dimensions and change their style to a company approved style.
Have you tried putting ‘None’?
Failing that wombat has a null node you could feed in.
according to the API doc, It’s necessary to add an ElementFilter as argument
an example
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
filledRegion = UnwrapElement(IN[0])
def get_DependDims(elem):
	#filterElem = ElementClassFilter(clr.GetClrType(DB.Dimension))
	# OR
	filterElem = ElementCategoryFilter(BuiltInCategory.OST_Dimensions)
	lst_dimIds = elem.GetDependentElements(filterElem)
	lst_dim = [doc.GetElement(xId) for xId in lst_dimIds]
	return lst_dim
OUT = get_DependDims(filledRegion)
Hello c.poupin;
The line “filterElem = ElementCategoryFilter(BuiltInCategory.OST_Dimensions)” in your example did the trick. I now need to process the results and get at the dimension style settings.
By the by, mid-way down the documents page, it says that the filter element Can be NULL to return all dependent elements. So I am still wondering, out of curiosity and future use, how do you pass a NULL? I did try “none” and “None” and that did not work.
Sincerely;
Michelle
NULL in C# is equivalent to null in Dynamo is equivalent to None in Python.
So the example of utilizing the Element.DependentElements method would be as follows in Python:
