Iterating through elements and getting their parameters Revit API
Hello all,
I am trying to basically use the e.GetParameterValueByName in python as opposed to DesignScript. No matter what I read on the API or in the forums I always get the same errors, so I am obviously misunderstanding a step that would make this work.
den = IN[0] #A list of Family Types plugged in via Dynamo
dln = []
for d in den:
	dln.append(d.GetParameters("Parameter Name"))
OUT = dln
However I always get the following error even though I can see in the API that this method exists for elements.
AttributeError: ‘FamilyType’ object has no attribute 'GetParameters
What do I need to do to make this work?
Have you imported the Dynamo RevitNodes library to python? Also, since you’re in an environment which can make API calls directly, I wouldn’t bother using this method and instead use the RevitAPI:
for d in den:
	rawRevitElement = UnwrapElement(d)
	p = rawRevitElement.ParametersMap["Parameter Name"]
	dln.append(p)
I have just read up on and learnt about UnwrapElement() which is crucial to make the code work.
so adding the
den = UnwrapElement(IN[0])
dln = []
for d in den:
	dln.append(d.LookupParameter("EFA FFE Code").AsString())
OUT = dln
makes it work. But thankyou for the excellent hint!
