Script Returning Null
"import clr
clr.AddReference('RevitAPI')
clr.AddReference('System')
#Functions for list handling
def ProcessList(_func, _list):
   return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def ToRevit(item):
	return item.ToRevitType(True)
if IN[1]==True:
	if isinstance(IN[0], list):
		bblist = ProcessList(ToRevit, IN[0])
		bblist = [ToRevit(IN[0])]
else: OUT = 'Change Toggle to True'
def collectElementsInBB(bb):
	outline = Outline(bb.Min, bb.Max)
	filter = BoundingBoxIntersectsFilter(outline)
	collector = FilteredElementCollector(doc, doc.ActiveView.Id).WherePasses(filter)
	return [e.ToDSType(True) for e in collector]
	OUT = ProcessList(collectElementsInBB, bblist)";
Can someone point me out what is wrong with the script. I am just trying to get a conditional out-put from the script. It will wait until the Toggle value turns true.
[/quote]
Unindent this line, the OUT should not be inside the DEF.
def ToRevit(item):
if IN[1]==True:
else: OUT = "Change Toggle to True";
Yes you are absolutely right about that. That was a stupid mistake. I have edited the script but still it’s returning an empty list.
I am still missing out something.
I don’t know what you exactly want but your script works fine by me:
