How do i make it
not sure we will need see your entire graph with all nodes expended and all warnings show, if any…try restart and delete all your cylinders as you probably have created in last run
Excuse me.
Now i want open it in revit.
Can you show me the solution to put it in revit ?
And I want make a color How do i ?
Thank you
Hi if you share a small sample rvt and your dyn graph we can take a look…
hi i mean a dataset, so we can remake the error…i guess you get some data from excel…hard to see, but if that the case then share that sheet as well…i cant tell you exackly whats wrong without that
i know, this my data excel
Design_Data_243.xlsx (14.3 KB)
Thanks you
and your graph and rvt as well
Chưa hoàn thiện.dyn (67.9 KB)
I guess you had some scale issues, here i have multiply with 1000 and should work…play around with it
Hi
But when i do like you
Why
I think this is the problem
It’s your
It’s me
My dictionary is not work
Yes a saw that in your graph , i swap that node to springs family instance by geometry…by the way where is that node from ?
sorry i dont understand your meant
What node
your family geomety node…it doesnt look like spring are you sure its the latest spring nodes…or is it a modified spring node ???
Here
right ?
I just update DynamoIron 2.7
dont update your ironpython stay in 2.7 version 2.5…but for the spring package, it looks right…not sure try uninstall the other spring UI package you have installed
Chưa hoàn thiện.dyn (78.7 KB)
I did install spring UI
When i still ironpython 2.7 version 2.5, is not work
But I will try
By the way
Do you know others ways to make the pile to revit environment ?
Yes i would do it with a real column pile family…not sure is it secant poles you try ??
