Display in revit
hey ! I am new in this group and in dynamo and revit !
I have a problem about the display in Revit.
I start a code about the insertion of a mesh in revit.
I have my model in the background of dynamo by nothing in Revit.
Someone can help me please ?
Thanks a lot and have a nice day :slight_smile:
Check it out
Hello…you will need to feed in a categori/material and a unique name if you will see your mess as direct shape…for just revit background view (blue lines) do what @Draxl_Andreas say
i already check this and it’s ok ! so unfortunately it’s not this ! :frowning:
I don’t know but i thought the was a difference between MeshToolkit mesh and Dynamo mesh
nårrhh ja…think you are right @Marcel_Rijsmus
Also missing inputs into the direct shape node. Light grey node name means the node is in a function state and not executing.
After converting to an out of the box mesh (there is a node for this in the Spring Nodes package), make sure you provide inouts for the other nodes as well.
