Could Anyone Help me :
1- I loaded the lunchbox package for dynamo and i used the diamond face in lunchbox it is totally different compared to the one in the tutorials it’s output just two xyz not polygons and points and surfaces i don’t know why ?
- so i used another package for diamond drawing by using surface and it is working but it’s output not divided all points and polygons and surfaces in one output i had to separate them with hardcoding to get the points
2- I need to create adaptive components as 4 points steel bars and glazing panel inside , i created adaptive 4 points components by revit and i connected it with the points i get from the diamond surface after getting the point lists, but it gave me an error ?!
- Here is the warning message
Warning: AdaptiveComponent.ByPoints operation failed.
An adaptive component could not be found or created.The input list of points does not have the same number of values required by the adaptive component.
– What i want to do is to take the output of the diamond surface and model a circular bars on the polygon and make a glass panels with surface inside
