I actualy try to put dimensions to my linked doors. I followed a script based on faces.
It seems to be that it doesn`t work. My geometry is too complex! Can i access just the opening from the door?
How can i put my dimensions on the opening(linked opening) Can i “sort out” my opening from the geometry?
setTextDimensionDoor_V0.dyn (90.4 KB)
You can take the ReferenceLines inside the Door-Family as a Reference for your dimensions.
Have a look at the GeniusLoci-Package.
You will get the Left and Right Reference of the Door with the FamilyInstance Reference By RefLine
Node and the input for the ReferenceType with the FamilyInstance ReferenceType
Could it be that i have linked-doors, because of the empty list?
Try “Left” and “Right” as ReferenceType.
next challange: create dimension with offset to refplane
refplanes are endles
Go for it! I’m sure you will find a solution.
