Distance between two elements
Hi!
I am looking for a way to check the Distance between two elements, for example, the door to the window? :slight_smile:
Try this.
3 444
thank you so much Ahmed… do you think i can place a dimension line between the elements ? :slight_smile:
شكرا أحمد :slightly_smiling_face:
@abdu2736 You may use the following to dimension to the door/window rather than a reference plane. Note that it does not account for non-orthagonal placements, and the families must have named centre reference planes. RUN IN MANUAL MODE.
Hi Ahmed,
I am not sure why to keep making one dimension, not seeing the different dimension:
EL1.0.dyn (89.3 KB)
Try to chop list of references then put the lacing to longest in the create of dimension node if auto does not work.
Hi Ahmed,
i still getting error :confused:
try to work on floor plan not 3d view to manage it to place the dimensions.
all good now! except that list [0] it works in weird way…
i guess "ReferencePlane.ByLine " acts weird !!
It’s because the line you created only draws it along the y axis, hence why all your dimensions are oriented along 1 direction. You will need to adjust the way the line is drawn to account for different orientations.
hi Blake, thank you for answering!
i will try ti use your way here
Let me know how it goes for you. I didn’t realize what your full intent was in the first post so it may be tweaked to better serve your needs. Happy to help troubleshoot.
I can send you you the files dyn, and rvt :slight_smile:
