Put, dimension with this solution,how?
I found this way… actullay i stuck to get correct reference elements. the correct faces from the opening.
can i sort by vertical elements, can i access the doors opening?
createDimensions.V1.dyn (72.6 KB)
Hi @Draxl_Andreas,
Here is an example using the reference planes of the door family :
Dimension door.dyn (20.4 KB)
Thank you, it workedm, but just for native Elements.
So it is a linked element! values are Null, i try find some nodes…
It should be, LINKED_Element Host, LINKED_FamilyInstance Reference ByRefPlane
…hmmm :confused:
