Placing Opening driven by host door values?
I have a architecture model loaded. At the place of the doors i want place my openings. these openings take the type values (length/height) from the doors - finished! So my script has no error. but nothing get placed?
So where is the issue? my opening is a generic model, wall hosted… like the doors… the openings only contain instance-parameter
it is placing it anywhere?
KR
Andreas
2022-05-06_16h35_44
SetOpeningsLinkedDoors.dyn (36.4 KB)
Hello @Draxl_Andreas
I’m sure problem here in InstanceByPoint
your family is host based - use instance by host and point
if it helps - mark it as solution
I will try it when i in the company…:wink:
Hello @y.Petrenko ,
So i struggle with the host question. how do i get my walls. I tried all elements of category but it faild.
Should i use bounding box from my linked walls? and looking what is inside in my native file?
SetOpeningsLinkedDoors.dyn (30.6 KB)
for Host you have to use a walls inside your native file (not linked) if you have it
that actualy the issue. i can`t know it. so i have to
1.) get the linked walls
2.) which walls inside
3.) these are my hosts
Hi @Draxl_Andreas
Believe @GavinNicholls did something similar that may be of use, link below for reference
Cheers KS
it works!
it delets one opening i don´t know why
… i will check the video
SetOpeningsLinkedDoorsV01.dyn (42.3 KB)
Hello @Kai,
Its a “almost” Solution, it places opening wall by wall, at least i am faster as i do it by hand!
Maybe i can adapt the script to manage more than one wall.
KR
Andreas
I think yes. Get BB from Windows/Doors
check if it intersect with your wals
group it
instance
SetOpeningsDrivenByDoors.dyn (71.2 KB)
Actually, i have just to find a solution, for a Wallselection @y.Petrenko
please prepare some example Revit file
tomorrow here in austria is 23:25 :wink:
Here in Ukraine is 00:27
Good Luck!
