Getting a List of Parameter Values from a List of Elements
Hi
I was unable to find something like that except maybe in one post but the images were way too small unfortunately.
I want to gather a list of parameter values from a list of sheets to export those into an excel sheet.
I thought I could just filter my desired sheets into a list and write a list with the 20 parameter names and use the node “Element.GetParamterValueByName”. But it seems like I either get one parameter of each sheet in a list or the first parameter of every sheet (if I apply layers) but never a list of 31 lists with 20 items each.
I doubt that this is complicated but I cannot finde the solution to this …
Element.Parameters
EDIT
I had misread the question :see_no_evil_monkey:.
Set the Element input to @L1. This will trigger longest lacing of the parameter names across each individual input as @L1 is a single item and auto lacing defaults to longest if a single item is given.
Cross Product lace instead of Auto lace.
Thank you. Both solutions work. Thank you!
If the spreadsheet will come back into Revit, I’d keep one row per sheet and preserve the exported element ID in a separate column. That way, sorting the workbook or renumbering sheets won’t break the match.
I work on ExyRev. Its DataForge command can export a sheet schedule to XLSX, preserve that mapping, and validate the edited workbook before applying updates. For a one-way export, the cross-product approach above already gives you the grid you need.
