How to get all parameters from elements - as explained in the link below (but sadly image is too small to see the solution).
Yes I want to change Sheet parameter values to be same as my another sheet.
However I do not want to type parameter names and values manually - as you suggesting.
Here what i did,
- I exported all sheet parameters to excel file so i can use for multiple projects
2.select the sheet that already filled and get all parameters values. - Filter the sheets that i want to fill.
- Set parameter value to selected sheets.
It worked. All parameters (except Sheet Number of course) copied.
Thanks @volkan.isik
Duplicate sheets with parameter values.dyn (17.5 KB)
