I am trying to output from Revit to Excel a list of revision clouds and some of their properties:
Revision Number
Sheet Number
Revision Date
Comment
So far I have been able to extract for the number, date, and comment. Extracting the sheet number has proven a problem. I would post my .dyn file, but since i am new, this forum will not allow me.
Does anyone have any recommendations? Is there Python Code that does this?
This is for a revision narrative. Any help will be greatly appreciated!
Sheet Number is not a property of a Revision. You will have to get all your sheets and query their Revision.
look into all parameters as I know is possible to determine what view the revision is on, and (assuming it wasn’t drawn on a sheet) then from the view you can pull the sheet number.
I think you can get OwnerView from a Revision, but that could be misleading depending on how your views are setup. I’m pretty sure I generally go from Sheet to Revision.
There is apparently some Python code that can accomplish this, but I am not familiar enough with Python (tres noob) to write it.
