How to get the Revision NUMBER on a Sheet with Python code?
I tried that code, but it does not work with flatten unique item lists as inputs…
# Import Element wrapper extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
revisions = UnwrapElement(IN[0])
sheets = UnwrapElement(IN[1])
Output = []
for sheet, revision in zip(sheets, revisions):
    revnum = []
    for rev in revision:
        r = Autodesk.Revit.DB.ViewSheet.GetRevisionNumberOnSheet(sheet, rev.Id)
        revnum.append(r)
    Output.append(revnum)
OUT = Output
although adding a list level in revision input works.
@ruben.romero check this:
This is because you are unnecessarily looping over the zipped list to get the revision when it is already accessible as ‘revision’. The reason it works when you add another list level is ‘revision’ is no longer and item which you cannot iterate over it is a list containing 1 revision.
Try:
# Import RevitAPI
import sys
Output = []
    #for rev in revision:
    r = Autodesk.Revit.DB.ViewSheet.GetRevisionNumberOnSheet(sheet, revision.Id)
    Output.append(r)
OUT = Output
