I’ve made some progress but now I’m stuck.
Im retrieving 4 parameters for each sheet (Sheet Number, Revision Number, Revision Description and Revision Date). So far so good. My problems comes when i want to format the information to send to Excel.
I was thinking of having the first column as the Sheet Number, the second one the Revision Number and so on. When i retrieve the information i only get 1 Sheet Number but i can get 2 different revisions for it. So my first problem is to be able to repeat the Sheet Number X number of time (unless someone knows a better way to send to Excel).
Here’s where i am so far and I’ve included the DYN
Thanks for any help
0.9.1_RevisionToExcel
Hi, would this work for you ?
Im gonna say no as each sublist needs to have the same amount of items to fill the row properly
Got it
how about this ?
![excel]|1746x838](upload://xHxHajuneHujAr8iceAPNkeIE9o.png)
That got me close enough to finish it
I was missing the damn long lacing in the count
and i added a List.Map at the end, result is spot on
Thanks a lot for your help
Hi Daniel first of all, thank you for your post. I am trying to produce something similar to yours. I had a look at your dyn file attached, but when I tested it came up with the following error: “Custom node definition is not loaded” my biggest challenge here is retrieving revision data. I think I tried all the nodes I have in dynamo but so far none of them worked. looks like the trick is in the “Revision on Sheet” node. If you could help me with that I would very much appreciate you. Regards Igm PD: I am new in dynamo and have no programming experience
that node is from a custom package called archi-lab.net so just search for that. Look under package manager.
GOT IT, Thanks Konrad!!
Wel, I managed to make the node works, but I cannot make the outcome looks as I wanted on a excel sheet.
I can only manage to show the info in one column as if it was a long list. What I would like though, is to display the data in columns and rows.
Attached a snapshot of what I am getting in excel and dyn. file if anyone wants to have a look and let me know what I am doing wrong and why I am getting the data in one column.
Thank you!RevisionRevitToExcel
Can you tell me what the story is with these nodes? I downloaded the .dyn file from Daniel at the start of this thread and it contains a node called “Revisions on Sheet” which seems to return the revision numbers for each sheet in the example. But when I search for that node I end up with “sheet.Revisions” instead and I have not been able to get the revision numbers out of it.
Any help here would be greatly appreciated.
