The direction grid lines and sections are placed affects which end the grid head and section head are placed. It’s easy enought to manually switch the heads (maybe even through Dynamo) but then you have to do it for every view (boo). But, if you rotate the grid/section 180 degress, it solves the issue! So far I don’t see a way to rotate grid lines (haven’t tried it with sections yet). Thoughts?
Related topics
| Section Views- Align sections | 6 | 824 | May 30, 2023 | |
| Rotate grid | 13 | 345 | January 15, 2025 | |
| Get Sections Views From Grids | 5 | 2522 | June 12, 2026 | |
| Section Views not vertical - Dynamo | 2 | 704 | October 18, 2021 | |
| Changing Section Marks in View (Cycle Head Types) | 3 | 1783 | February 26, 2020 |
